Activity Forums Maxon Cinema 4D Light in toy bear’s glass eye
  • Light in toy bear’s glass eye
    Posted by John Mcmullin on November 15, 2017 at 2:53 pm
    I’m trying to recreate this eye:
    I’ve tried playing with caustics, using a curved glass surface on top of an iris layer, but can’t get anything with the same richness, sheen and colour. And the other problem is the lighting. If I concentrate on lighting the eye, the caustics create a lot of reflected light which is affecting the bear’s hair around the eye.
    Many thanks,
    John
    John Mcmullin replied 8 years, 10 months ago 3 Members · 3 Replies
  • Brian Jones
    November 15, 2017 at 8:35 pm
    re caustics, if surface caustics are off it should help limit light effects on the surrounding hair
  • Adam Trachtenberg
    November 15, 2017 at 8:48 pm
    Personally I would try to avoid the caustics and instead use an anisotropic metal reflection on the iris to simulate the light effect.
    Example:
    11864_beareye.c4d.zip
  • John Mcmullin
    November 15, 2017 at 10:03 pm
    Hi Adam.
    That certainly is very similar. Much simpler and and more effective than what I was doing. I think I misunderstood the physics of what was causing the colouring on the bed of the bead.
    Thanks so much for a great solution.
    Best wishes,
    John
