Activity Forums Adobe After Effects light from rear
  • light from rear
    Posted by James Hughes on February 27, 2012 at 7:43 am
    if i add a light to a comp it will light up the 3D layer that is stacked underneath it.
    When I move the light position to be behind the 3D layer, why doesn’t it backlight that layer creating a halo like it would in real life?
    cheers,
    Andrew Somers replied 14 years, 5 months ago 2 Members · 1 Reply
  • Andrew Somers
    March 12, 2012 at 7:27 am
    Halo as in reacting with the atmosphere?
    There is no “atmosphere” in AE – though you might be interested in the plug in LUX from Trapcode, which might help you achieve the effect I think you are looking for. It makes AE’s comp light visible.
