Activity Forums Adobe After Effects Light Factory 2.5 and Nucleo Pro 2 crashes
  • Light Factory 2.5 and Nucleo Pro 2 crashes
    Posted by Paul Hamrick on August 1, 2007 at 5:15 pm
    I installed Nucleo Pro 2 on AE CS3 (Windows, 4 CPU, 8Gig RAM) – works great, renders FAST, no problems. A few days later I installed Knoll Light Factory 2.5 and am not having as good of luck.
    With any of the NP2 “Spec” render or preview features enabled, Nucleo crashes when a Knoll preset is applied. Without Nucleo “enabled” in the project, AE CS3 crashes when Knoll is applied (to a comp solid). Further, when crashed AE gives the “last chance” to save the project before closing – if the project is saved AE crashes when that project is reopened.
    The system seems to be stable otherwise, and after uninstalling Knoll 2.5, I haven’t had any problems rendering in AE or Nucleo.
    Anyone else had similar experience that resulted in a fix or workaround?
    Paul Hamrick replied 19 years, 1 month ago 2 Members · 2 Replies
  • Steve Forde
    August 1, 2007 at 10:24 pm
    Unfortunately its a known issue with Light Factory. Double unfortunately, its a problem with Light Factory. The good folks at Red Giant Software are aware of the problem, and assure a patch is forthcoming.
    Steve
    GridIron Software Inc.
  • Paul Hamrick
    August 2, 2007 at 7:07 pm
    If they are aware of the problem, they don’t seem to want to admit it.
    This is the response that I got from Red Giant:
    Update for Case #3109 – “Knoll light factory crashes AE CS3 all operations”
    Paul,
    If you are using Nucleo, please disable the
