Activity Forums Boris FX Light effect with BCC
  • Light effect with BCC
    Posted by Catalin Brylla on September 5, 2008 at 1:41 pm
    I am using BCC and Avid Media Composer, and I want to do the same effect as this really cool plug in (which is only for Final Cut):
    https://www.volumetrix.tv/
    Any idea how to do this with BCC? How can I make the ray effect so that the text actually appears with the light.
    Thanks.
    Sergio Anaya replied 18 years ago 2 Members · 4 Replies
  • Sergio Anaya
    September 5, 2008 at 6:16 pm
    Well I not an expert but the one in the top of the web page (volumetrix) you can do it as follow:
    1.- Create your title as you want
    2.- applying the light zoom effect to the title
    3.- Animate the title with as typing machine “effect” (check the last tag in the title options)
    4.- Animate the ligth effect, in the X position, the first key frame and the last key frame, you will create that the ligth will be move fromn left to rigth or rigth to left, as you want.
    I think now you have the big picture how to do it, practice and experiment, I sure you will do the effect as you want!.
    Best Regards
    LIQUID 6.1
    3.2 Gb processor
    1 Gb DDR
    128 MB CARD
  • Sergio Anaya
    September 8, 2008 at 2:15 pm
    I was trying to do this effect this week end, that I did was:
    – Apply the puffy light effect in the top of the title
    – Check the type on tag in the title options.
    – Then animate the light effect and the title as you want.
    I expect this helps!.
    LIQUID 6.1
    3.2 Gb processor
    1 Gb DDR
    128 MB CARD
  • Catalin Brylla
    September 11, 2008 at 12:01 am
    Thanks a lot Sergio. It still does not look the same way (neat and cool), but I am getting the gist. If you managed to do it, would you mind sending me your settings?
    Thanks.
  • Sergio Anaya
    September 11, 2008 at 3:47 pm
    Catalin
    Good that my comments help you!!!
    I did not do the effect as it is in the web page, I am not a pro with BR, I just was traying to give you the big picture, you can play with it.
    I think in this effect you can include the blur filter to the light, you will have other different wiew, also the light intensity in the effect is bigger that the standard in the BR ligth effect.
    I this case I recomend you first get the settings of the ligth as you want, then animate the ligth and the last animate the title.
    I expect this helps.
    Best regards
    LIQUID 6.1
    3.2 Gb processor
    1 Gb DDR
    128 MB CARD
