Activity Forums Maxon Cinema 4D Light diffusion
  • Light diffusion
    Posted by Maxim Moisseev on December 16, 2010 at 10:38 pm
    Dear friends!
    How do I set up a transparent material that has a light diffusion? Like a dirty glass. When you illuminate a dirty glass by a torch, you can see light spot from two sides of glass.
    I tried to do everything I can with standard C4D materials.
    http://www.transscreen.ru – clear projection films and touchscreen.
    Maxim Moisseev replied 15 years, 8 months ago 3 Members · 5 Replies
  • Adam Trachtenberg
    December 17, 2010 at 12:25 am
    I think you may be looking for the effects>backlight shader. Can you share a picture of the look you’re trying to achieve?
  • Brian Jones
    December 17, 2010 at 1:17 am
    maybe exit reflections?
  • Maxim Moisseev
    December 17, 2010 at 9:46 am
    I am trying to make a rear-projection screen.
  • Adam Trachtenberg
    December 17, 2010 at 3:55 pm
    The way to do that is to use a light as your projector and put a material on your screen that has the backlight shader in the luminance channel. The light also has to have a texture which should have your image or footage in the transparency or alpha channel. The texture tag should be set to flat projection.
    Example (R12): 1416_rearprojection.c4d.zip
  • Maxim Moisseev
    December 19, 2010 at 8:48 pm
    Thank you, Adam! This is EXACTLY what I asked for.
