Activity Forums Adobe After Effects Light created Shadows on a Transparent Plane?
  • Light created Shadows on a Transparent Plane?
    Posted by Matt Abron on September 30, 2009 at 8:39 pm
    Hi All,
    I am in need of rendering a project without a background…Alpha.
    I want to somehow render out the dynamic shadows that are created by light sources to render to the background plane…but the background plane to be transparent minus the shadowing…
    Is it possible?
    If not anyone have a way to create realistic shadowing from the layer effect? Like an expression..
    Thanks.
    BTW: Anyone know the bit of HTML Code to get that border effect to turn off around my logo? I know it is border=”0″ but my syntax seems wrong…anyhoo, one thing at a time…
    matt
    Luke Di rago replied 16 years, 10 months ago 3 Members · 2 Replies
  • Jeremy Fabiano
    September 30, 2009 at 9:12 pm
    the correct syntax (whether it’ll work or not) is
    open chevron a href=’URL’ close chevron openchcevron img src=’URL TO IMAGE’ border=0 close chevron open chevron /a close chevron
    sry i couldnt get the CODE thing to work…
    As for the other part, sounds like a job for a 3d app, dunno if AE can do it or not, I’m not qualified to answer..
    -Jeremy
    If you didn’t supply enough information I will start making assumptions. I’m usually wrong when I assume.
  • Luke Di rago
    November 5, 2009 at 6:11 pm
    I was looking for the same effect, and after thinking a while how to achieve that in AE, I’ve found a simple workaround:
    If you make a white solid in 3D, and the shadows are projected with a light, you can use that as an occlusion pass; a white plane with dark shadows only, and then applied as Multiply, will do a similar effect to what a 3D OCC pass would do.
    You have to set the white solid to accept shadows, but no lights (in Material Options, shortcut AA on the layer) , and then play around with the opacity, and control the sharpness/softness of the shadow with the light controls.
    Hope this helps you,
    Luke!
