Activity › Forums › Adobe After Effects › Light conducting grid…
  • Light conducting grid…
    Posted by Harald Krytinar on January 24, 2007 at 10:27 pm
    Hello,
    I would like to create a grid that “transports” light particles along its paths.
    My idea was the following:
    1) create a grid
    2) create a fractal noise cycle
    3) overlay the two with Classic Dodge
    This way it “sort of works”, but it really changes the overall saturation of the grid.
    Would there be a way to do something with Expressions or any other way for the grid to
    only be effected by the highlights of the fractal noise background?
    Off topic, only out of interrest:
    Would there be an efficent way to really make the light particles follow the grids path?
    Many thanks for your ideas…
    /Harald
    Aharon Rabinowitz replied 19 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Mylenium
    January 25, 2007 at 6:31 am
    [max_iqueu] “Would there be a way to do something with Expressions or any other way for the grid to
    only be effected by the highlights of the fractal noise background?”
    Expressions cannot acces pixel data. What you have to do is tu unmultiply your Fractal Noise using XMult or similar tools. Once it has Alpha information, it’s much easier to tweak it.
    [max_iqueu] “Would there be an efficent way to really make the light particles follow the grids path?”
    Not in AE. You need a 3D program for that. Depending on what you are rtrying to do, you may get some simplistic stuff using Trapcode’s Particualr with the Path mode, but everything else is really not for AE.
    Mylenium
    [Pour Myl
  • Morebo
    January 25, 2007 at 8:06 am
    Geomancy from digital Anarchy might do the trick for you.
    Morebo
  • Mylenium
    January 25, 2007 at 9:05 am
    Yes, You are so right. Completely forgot. Grid Lines may work.
    Mylenium
    [Pour Myl
  • Harald Krytinar
    January 25, 2007 at 9:39 am
    Thanks you very much, that really helped.
    The plugin is even affordable @ 99US$
    I’ll give it a test run and see what it looks like.
    Is there a way to xMult within AE?
    How can I create an Alpha Mask within AE? Only by rendering?
    Mylenium, would you mind explaining me “unmultiplying”, please?
    Many thanks for your help again,
    /Harald
  • Aharon Rabinowitz
    January 26, 2007 at 2:14 pm
    Here’s what I’d do:
    Create a medium-blue grid
    duplicate the grid layer.
    Set the top layer to the Add blending mode
    add the fractal noise effect to the layer on top
    Set the fractal type to strings
    Set the EFFECT’S blending mode to Darken
    Set the Effect’s contrast to a very high number
    Set the effects Brightness to a low or negative number
    Animate the effects evolution and/or transform properties
    Add the glow effect and set the glow threshold to very low (You might want to do this earlier so that you can see things a little better
    (Alternatively, to this last step, you could change the grid effect’s color to a brighter color and add a blur effect).
    That should do it.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:
    https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
  • Harald Krytinar
    January 27, 2007 at 8:39 pm
    Hello Aharon,
    many thanks for your “How to…” I tried it out already and it works just great.
    I actually used an adjustment layer as the base. Don’t know if that causes problems later on… I guess to top it off, a little Motion Blur and the result will be stunning – for me anyway.
    Do you think there is a way to eliminate the grid structure completely? I didn’t really manage. I guess I could use another contrast effect ontop of it? But I’m thinking: there must be a more elegant way?
    Off topic:
    Many thanks also for your AE-Podcasts. It really helped me to find my way round AE much faster. It’s not just what you’re actually explaining but all the little workflow things around it, that make it so interresting. And fortunatly it’s not as “stiff” (as in: uptight) as the Ad*be training DVDs.
    Best,
    /Harald
  • Aharon Rabinowitz
    January 27, 2007 at 11:01 pm
    Hi there-
    I think you could get rid of the grid structure if you approached the porject from a different perspective. Create a grid, and then create another solid layer with the same fractal noise effect. Use that fractal noise effect as a Luma matte for the grid layer, and you will only see the parts of the grid that fall under the whiter parts of the fractal noise. Then either add an adjustm,ent layer with a glow effect, or nest the comp in a new comp and add the glow effect to the nested comp.
    I’m glad my training is helping you.
    Aharon Rabinowitz
