Activity Forums Adobe After Effects Light Beams
  • Light Beams
    Posted by Ben Mettler on September 8, 2011 at 5:02 pm
    I’m trying to figure out how to make light beams that look similar to the image below. Does anyone have any ideas or know of a tutorial that does something similar?
    Kevin Camp replied 15 years ago 2 Members · 1 Reply
  • Kevin Camp
    September 8, 2011 at 5:21 pm
    create a spiky ball (knoll light factory has good effects for this, or you could try the standard lens flare, but the lens artifacts may not work out), then add something like cc fast radial blur set to brightest, offset the center to get the direction you want and crank up the amount.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
