Activity Forums Adobe After Effects Light beams question
  • Light beams question
    Posted by Ian Collister on December 8, 2009 at 10:51 pm
    Hi all
    This should be quite simple, im just having a little trouble.
    Imagine shining a torch through a cheese grater in the dark, you would get lots of little light beams, they would move about as you moved the torch etc.
    I want a similar effect, but i have a layer with an ornate shape cut from it, using a mask, rather than a cheese grater. I then want to shine a light through from the other side of the said ornate mask and hopefully get some interesting beams of light.
    I couldnt get anything to work with the standard lights in AE, (the light beams just didnt show up) so i had a go with a trapcode lux layer, hoping it would help make the beams appear, which they did, but my ornate cheese grater layer then disappeared!
    Any help, as ever, is much appreciated.
    Cheers all!
    Ian Collister replied 16 years, 9 months ago 4 Members · 4 Replies
  • Brian Charles
    December 8, 2009 at 11:15 pm
    There’s always Trapcode Shine, or an alternative method using the method described here:
    https://ae.tutsplus.com/tutorials/motion-graphics/learn-how-to-create-a-light-rays-custom-effect-from-scratch/
  • Michael Szalapski
    December 9, 2009 at 12:25 am
    If you’ve got Shine, this tutorial from Trapcode will help you. (Or, if you want, you could use the CC plugin that comes with AE, [I forget it’s name and I’m not at my AE machine] instead)
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • David Bogie
    December 9, 2009 at 6:59 pm
    You might also look up “disco ball” in various AE tutorial sites. it uses only the stock filters but it will not create true, 3D, volumetric light beams. Fro that you must have a more sophisticated filter like Trapcode.
    bogiesan
  • Ian Collister
    December 10, 2009 at 8:57 pm
    Cheers all! Much appreciate the help, got where i needed to go in the end.
    Thanks again!
