Activity Forums Adobe After Effects light beam
  • light beam
    Posted by Kayla on October 25, 2006 at 12:57 am
    You know how you often see a quick vertical bean of light animate through text to make it look flashy. How is that done?? Through a mask perhaps? Can you guys give me pointers? Thanks….
    Jimmy Brunger replied 19 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Mike Clasby
    October 25, 2006 at 1:53 am
    Trapcode’s Shine is the industry Standard, but AE’s native Render > CC Lightwaves is a decent substitute, although I like Blur & Sharpen > CC Radial Fast Blur (put it on a Dup (Ctrl D) above the text layer) it spreads the light a little more evenly, play with the controls.
  • Kayla
    October 25, 2006 at 4:33 am
    Thanks…but was a Dup layer (control D)?
  • Kayla
    October 25, 2006 at 4:34 am
    i meant…what is a Dup layer?
  • Mike Clasby
    October 25, 2006 at 4:45 am
    Sorry, I mean duplicate the layer, select the layer and either Edit>Duplicate or Ctrl D. It just makes another copy of the layer, and the new layer is on top, and it’s sometimes handy for doing effects on since they can degrade the layer, and/or you can put an effect on the layer and use a Blending mode that gives a nice effect with the original layer below. In the Case of Radial Fast Blur, it kindof destroys the text layer when it makes the light waves, so if it’s a dupped layer on top you can still see the original text underneath.
  • Kayla
    October 25, 2006 at 5:09 am
    ah ok thanks!
  • Mark
    October 25, 2006 at 10:47 am
    I personally like the lights from BCC4. They are very cool and come with many presets. I like the fact that I have full control over the noise inside the light.
    Mark
  • Jimmy Brunger
    October 25, 2006 at 11:28 am
    Or for a ‘vertical light’ or metallic shine effect using masks, look at an old trick by Aharon for putting a shine through text/layers: https://www.creativecow.net/articles/rabinowitz_aharon/text_wipe_on/CC_Wipe_FullCD.mov
    Adapt it for your project using the same principles.
    Have fun!
    *AE 5.5 Pro – *PS CS1 – *Combustion 3
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / BMD DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation
