Activity › Forums › Adobe After Effects › Light a Single Object
Posted by Glenn Takakjian on August 31, 2009 at 6:48 amIs it possible to have a light effect 1 specific 3D object and not another.
C4D has the include/exlude function. Anything like this in AE?
TAK
Tim Wilson replied 5 years, 6 months ago 5 Members · 5 Replies -
Chris Forrester
August 31, 2009 at 2:39 pmYou can do something like this but not as elegantly as a 3D program.
The trick is to set the adjustment layer switch for the light you wish to have some form of linking. The next part of it is to place the 3D layers below this light. This light will only effect those layers below now and none of the layers above it.
It has many limitations but as far as I’m aware (I am a CS3 user) this is the only light linking that can be done.
Obviously stacking more lights above might effect layers that you don’t wish to but this might be enough to do what you want
Regards
Chris Forrester
demoreel http://www.chrisforrester.tv -
Tyler Paul
August 31, 2009 at 3:08 pmHere’s the Tutorial.
“Life Should Come With Backround Music”
-Brown Sugar Studios- -
Glenn Takakjian
August 31, 2009 at 5:45 pmThanks. Exactly what I needed.
It would be nice in the next version of AE if they could let you link a light to a specific object(s) so you don’t have to deal with the layer issue. But this worked great.
TAK
Tim Wilson
February 27, 2021 at 6:37 amHi Marieke,
We are in the process of moving our tutorial library from its previous home to our new servers, so for now, all of our video tutorials are available on our YouTube channel. Here is the direct link to Eran’s “Adjustment Lights” tutorial: https://www.youtube.com/watch?v=VPzRO3wn9EU
Regards,
Tim Wilson
Editor-in-Chief
Creative COWSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
