Activity Forums Avid Media Composer Lift/Overwrite Button on Express DV
  • Lift/Overwrite Button on Express DV
    Posted by Nfocus on May 4, 2005 at 7:52 pm
    I’m trying to use the lift/overwrite button to slide a video clip to match the audio. Normally on News Cutter and Composer you can move a clip frame by frame, for some reason on Express DV it doesn’t to that. Is there a setting I can change to adjust it?
    Samuel A. martin replied 21 years, 4 months ago 5 Members · 5 Replies
  • Charley King
    May 4, 2005 at 9:46 pm
    I’m not sure if this will do what you want, but add filler for a couple frames then use trim tool to slide it.
    Charlie
  • Jon Zanone
    May 5, 2005 at 11:29 am
    Do you have the timeline view zoomed in enough? Try ‘command or control + [ or ]’. It gives you much more better control than the little slider. Once you are zoomed in, you should have a little better control.
    Jon
  • Carl Amoscato
    May 5, 2005 at 3:38 pm
    Not sure if this works on XDV, but on Adrenaline to go frame by frame in segment mode you press and hold the ALT key while dragging.
    good luck,
    Carl
  • Nfocus
    May 5, 2005 at 4:25 pm
    I’ve zoomed in all the way (that’s how Adreneline and Composer work best) and that didn’t work, so I’ll try the ALT button. Thanks!
  • Samuel A. martin
    May 5, 2005 at 9:54 pm
    use the frame by frame trimming buttons on your keyboard
