Activity Forums Boris FX Particle Illusion Library Trees
  • Posted by Reber Clark on February 26, 2011 at 9:04 pm
    I have two old locations for emitters, in addition to the location I use, showing up in my Manager Library Tree window.
    How can I delete these old library paths? I see how to add a new path but not how to get rid of old ones.
    Thanks.
    In theory there’s no difference between theory and practice – but in practice there is.
    Reber Clark replied 15 years, 6 months ago 1 Member · 1 Reply
  • Reber Clark
    February 28, 2011 at 1:25 am
    Figured it out. While dealing with other pI3 issues I deleted these libraries OUTSIDE of pI3. That was the mistake. Therefore the “delete library path” button did not show up in the library manager and I was stuck. My solution was to re-add the library paths – each with a copied emitter in them – outside of pI3. Then in the library manager the “delete library path” button appeared and I could delete those paths. I then deleted the folders form my hard drive.
