Activity › Forums › Adobe Encore DVD › Library panel icons in Encore CS6
  • Library panel icons in Encore CS6
    Posted by Alfred Guzzetti on June 9, 2013 at 9:25 pm
    I bought Encore CS6 yesterday to make Blu-Rays and I’ve gotten it up and running (more or less). But in the Library panel, the only one of the 8 icons that works is the one on the extreme left, which displays the chosen set. If I click on any of the other 7 icons (including the second one, which is supposed to display the buttons within the set), nothing happens. I’ve reinstalled Encore but that didn’t fix it. I did originally install the library of “enablers” (or whatever they’re called) from the supplementary DVD and the library is there all right, but the sort function doesn’t work. I’d be grateful for any help.
    Alfred Guzzetti
    Mac Pro Quad 2.66GHz 4GB RAM
    Intensity Pro card
    OS 10.7.5
    Media Composer 6.5
    Sorenson Squeeze 8.1
    Final Cut Pro 6.0.4
    DVDSP 4.2.1
    Alfred Guzzetti replied 13 years, 3 months ago 2 Members · 2 Replies
  • Jeff Pulera
    June 10, 2013 at 3:13 pm
    Hi Alfred,
    Adobe no longer includes the full library of DVD menus and buttons with the standard install – you must download that content and install separately. I’ve only done it on the PC, but it works and I then get a large selection of images to work with.
    Please see this link – https://helpx.adobe.com/x-productkb/multi/library-functional-content-missing.html
    Scroll to the bottom where it says “Additional solution: Install the Resource Central library content”. The top of page just re-installs menus you already have, you want to follow the lower instructions.
    Thank you
    Jeff Pulera
    Safe Harbor Computers
  • Alfred Guzzetti
    June 10, 2013 at 3:31 pm
    Jeff,
    Thank you. This solves it. The Adobe online tutorials and documentation I found don’t mention this. I expected to find everything I saw in the tutorial (the one posted by the nice guy in the big truck, which seems official or semi-official).
    Alfred Guzzetti
    Intensity Pro card
    OS 10.7.5
    Media Composer 6.5.2
    Final Cut Pro 6.0.6
    Compressor 4
    DVDSP 4.2.1
