Activity › Forums › Adobe After Effects › Libraries Linking
  • Libraries Linking
    Posted by Allen Bullman on July 15, 2015 at 11:03 am
    I have created elements in PS and IL for use in PP an AF, I created a new library to put them in. That part does fine, and I can see them across all applications. When I am at work on my PC creating a AF project dragging the elements from the library into the project everything works great. Here is where the issue starts then I come home to pick up where I left off and I can see the elements in the library panel but they are not linked in the project anymore. I get color bars showing the image is missing. Should it not be looking to the cloud for this images and not the local pc?
    Todd Kopriva replied 11 years, 2 months ago 2 Members · 1 Reply
  • Todd Kopriva
    July 17, 2015 at 8:50 pm
    No, the project is still needing to know where the files are on disk. When you’ve added assets to the project from a library, you’ve just taken a typical import step, and there is no retained connection back to the cloud for this asset.
    After Effects product manager and curmudgeon
    After Effects team blog
