Activity Forums Compression Techniques libraries like libfaac and lame not present after install
  • libraries like libfaac and lame not present after install
    Posted by Marco Berger on May 24, 2011 at 4:25 pm
    Hay!
    For two weeks now I’ve been trying to fix that problem. I installed all the libraries and codecs, put them in the configure command and it does not return an error so they were found and all is ok.
    Then I compile, still everything ok.
    When ffmpeg is installed, I can compress videos and all, but some libraries are not there (that I installed) like mp3lame, libfaac, libvpx, etc.
    Using ffmpeg 0.7 with Linux 2.6, 64bits processor
    Thanks for any help
    Marco Berger replied 15 years, 3 months ago 2 Members · 2 Replies
  • Michael Rampe
    May 24, 2011 at 10:12 pm
    [MArco Berger] “I installed all the libraries and codecs, put them in the configure command and it does not return an error so they were found and all is ok.
    Then I compile, still everything ok.”
    These need to be enabled in the configure line (–enable-libx264 –enable-libmp3lame –enable-libfaac) along with –enable-nonfree. Post you FFmpeg configure flags (output from terminal) and I will take a look.
    Michael
  • Marco Berger
    May 25, 2011 at 1:14 pm
    My configure line was as follw:
    ./configure –prefix=/usr –libdir=/usr/lib64 –mandir=/usr/share/man –disable-avisynth –enable-avfilter –enable-libfaac –enable-libgsm –enable-libmp3lame –enable-libopencore-amrnb –enable-libopencore-amrwb –enable-libx264 –enable-gpl –enable-nonfree –enable-postproc –enable-pthreads –enable-shared –enable-swscale –enable-vdpau –enable-version3 –enable-x11grab –enable-libvorbis –enable-libvpx –enable-libtheora –enable-libdirac
    But I found “a” solution. Using ffmpeg auto-installer, one command and everything is ok. Much simpler.
    I tried running ./configure again just to show you, but it produces nothing in the console, maybe because it is now installed right.
    Thanks anyway!
    Marco
