Activity › Forums › AJA Video Systems › LHi Sony 1500 SDI audio very low
  • LHi Sony 1500 SDI audio very low
    Posted by Scott Davis on December 14, 2010 at 8:24 pm
    I am using a rented system with the LHi a Sony 1500 deck all connected via SDI. My audio is coming in very, very low. Any ideas as to what I am doing wrong?
    Scott Davis replied 15 years, 9 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    December 14, 2010 at 8:28 pm
    What do the meters on the front of the deck tell you?
    Are they low there as well?
    And just to double check, in your Kona control panel and the INputs tab, the audio is set to embedded?
  • Scott Davis
    December 14, 2010 at 8:31 pm
    Thanks Jeremy, I just solved it. As usual, it was something really simple. The audio levels adjustment knob was set really low. I adjusted up and now all seems fine. Thanks anyway.
    Scott Davis
    View Scott Davis's profile on LinkedIn
