Activity Forums Apple Final Cut Pro Legacy LHi down convert
  • LHi down convert
    Posted by Nobby Clarke on April 21, 2010 at 4:21 pm
    I am trying to down convert DVCPRO HD to standard definition using the LHi control panel while playing the video through Final Cut Pro and recording the playback through a DVD recorder. What settings do I have to input into the LHi control panel to do this correctly?
    I have RGB going into the DVD player and Composite and HDMI coming out of the DVD player.
    Many thanks
    Jeremy Garchow replied 16 years, 5 months ago 3 Members · 2 Replies
  • Shane Ross
    April 21, 2010 at 4:48 pm
    You need to set the ANALOG OUTPUT to 525i. Then you will see a little DOWNCONVERT box appear between the Frame Buffer and the output triangle.
    Shane
  • Jeremy Garchow
    April 21, 2010 at 5:14 pm
    Leave FCP in the HD easy setup that matches your footage, then open the control panel and set the analog output to secondary and 525i like Shane said.
    Jeremy
