Activity › Forums › AJA Video Systems › LHe Video out while digitizing from DV/FireWire
Posted by Floh Peters on August 30, 2006 at 4:28 pmHi,
I have a very basic question regarding our FCP/Kona LHe setup: I
Jeremy Garchow replied 20 years, 1 month ago 2 Members · 3 Replies -
Jeremy Garchow
August 30, 2006 at 4:59 pmNope. When you select firewire, the Kona is essentially “turned off” in FCP. The only way you can monitor is if you use the inputs of the card (SDI, Component, etc.) You will have to monitor your dv deck if you are coming in firewire.
Jeremy
Floh Peters
August 30, 2006 at 5:05 pm[JeremyG] “Nope. When you select firewire, the Kona is essentially “turned off” in FCP.”
Um, thanks a lot. At least I
Jeremy Garchow
August 30, 2006 at 5:33 pmIt makes sense really, all data is coming into the firewire port and not the Kona card. I’m not sure the requirements for handing off that info to the Kona card.
Jeremy
