Activity Forums AJA Video Systems LHe connect 4 ch audio to BVW-75??
  • LHe connect 4 ch audio to BVW-75??
    Posted by Brian Tario on April 24, 2007 at 9:53 pm
    I have a client coming in next week that’s bringing some Beta SP tapes with 4 channel audio on them. Obviously my PVW-2800 is only 2 channel, so I’m renting a BVW-75 deck. I’ve never used this deck before…does it accept SDI? If not, how can I get I/O for 4 channel audio with the LHe and the BVW-75? Many thanks in advance, Brian
    Jeremy Garchow replied 19 years, 4 months ago 4 Members · 5 Replies
  • David Roth weiss
    April 25, 2007 at 12:33 am
    The old fashioned way… You’ll have to do two passes.
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Jeremy Garchow
    April 25, 2007 at 2:16 pm
    Or rent that player only deck that takes BetaSP, Digibeta and BetaSX and outputs all that to SDI. I can’t remember the model number of it off hand. J10-SDI or something like that…
    Jeremy
  • Brian Tario
    April 25, 2007 at 10:56 pm
    Unfortunately the J-10 and J-30 don’t output all 4 channels of audio over SDI simultaneously…you have to pick either 1 & 2 or 3 & 4. But the DVW-M2000 apparently will, it’s just a helluva lot more $$$ to rent.
    Can anyone out there confirm that renting the DVW-M2000 will be the answer to my needs? Thanks a lot!
  • Szumlins
    April 25, 2007 at 11:30 pm
    Might be more than you want to spend, but you can buy an audio disembedder mini converter from AJA (HD10AMA) to pull 4 channels of audio via SDI but still send your video component. Depends on how often you have to do this, but it is a viable option.
    -Mike
  • Jeremy Garchow
    April 26, 2007 at 3:09 am
    Weird, i thought you could…it has been a long time since I used it. All the specs I find say it outputs 8 channels of audio (which I assumed to be four channels in the Beta world and I swear I captured 4 channels). Oh well. I have no experience with the DVW-M2000, sorry.
    Jeremy
