Activity Forums AJA Video Systems LH anologue video out
  • LH anologue video out
    Posted by Ross Marshall on January 9, 2006 at 3:22 pm
    Thinking of getting the LH to capture SDI and master out using SDI onto DVC Pro. Need video out in analogue for use with patch pannel and video monitoring. Is it right that the analogue component out on the card can be configured to output three composite out (BNC) instead. Used the IO before but never used the Kona cards.
    Cheers
    Ross
    Gary Adcock replied 20 years, 7 months ago 2 Members · 1 Reply
  • Gary Adcock
    January 9, 2006 at 4:00 pm
    [Ross Marshall] “Is it right that the analogue component out on the card can be configured to output three composite out (BNC) instead.”
    the component can also be configured as composite, Y/C ( with extra cable) and component, the LH cannot do multiple composite signals without additional hardware, If you have an I/O that can convert the SDI out to the additional analog signals.
    if you are going that way get a Kona2 so that you have the upconvert also.
    Gary Adcock
    Studio37
    HD and Film Consultation
    Chicago, IL USA
