Activity Forums AJA Video Systems LH Analog Audio Issues
  • LH Analog Audio Issues
    Posted by Joe Pitkin on January 21, 2008 at 3:18 pm
    Okay,
    I’ve inherited a system with my new gig that has an KonaLH card, and breakout box.
    I had originally thought that I was the victim of a bad cable out of the breakout box, so I replaced the audio ch2 cable. It was still crackling and soft. So I switched over to the XLR breakout cable. Still have a CH2 that is unusable. CH1 sounds perfect, nice and clean.
    Is this a known issue? Should I send the card to Kona for repair? I haven’t yet tried the AES/EBU audio since I don’t have anything that’ll play it.
    I couldn’t really find anything on the forums about a problem like this, but wanted to konw if it was something easy to fix.
    Joe Pitkin
    Joe Pitkin replied 18 years, 8 months ago 2 Members · 4 Replies
  • Bob Zelin
    January 21, 2008 at 3:31 pm
    move the CH 1 cable that works fine into channel 2 – is there any audio now ?
    The Kona LH came with an “octopus” break out cable that did not use the Kona KL breakout box. Do you know where this cable is ? You can try using this cable, to confirm that the card is ok (or broken), and this is not just an issue with the Kona KL box.
    Bob Zelin
  • Joe Pitkin
    January 21, 2008 at 3:42 pm
    That’s exactly what I’ve done to confirm that it’s the analog output off the card and not a cable / breakout box / board input issue.
    I get the same noise if I go:
    Kona Card -> breakout box -> Board
    Kona Card -> Octopus Cable -> Board
    It’s not the input on the board, as I’ve used multiple and it follows CH2 Analog.
    My gut is that the board got fried at some point before I got here, and no one noticed or cared.
  • Bob Zelin
    January 21, 2008 at 5:37 pm
    then you know what to do next !
    bob Zelin
  • Joe Pitkin
    January 21, 2008 at 6:50 pm
    Yeah, Rip the card out and send it back to AJA.
    I ended up talking with an editor who’s spent some time on the system as well. He went “oh yeah, I forgot about that. I think someone turned the phantom power on and blew the output”
    Just what I don’t need…
