Activity Forums AJA Video Systems LH 4.0 driver install refuses???
  • LH 4.0 driver install refuses???
    Posted by Chris Borjis on July 14, 2008 at 9:09 pm
    I want to try the 4.0 drivers to see if this fixes my rs-422 problems before officially contacting aja.
    for some odd reason 4.0 or 5.0 drivers REFUSE installation.
    The error I get is:
    YOU CANNOT CONTINUE, THERE IS NOTHING TO INSTALL
    5.1 driver is the only one that will install.
    I am not running leopard and have no future plans to.
    4.0 should install, I have admin rights and have successfully
    uninstalled 5.1
    There are no conflicts according to the checker, I am running the current supported version of quicktime and os x.
    any ideas?
    Chris Borjis replied 18 years, 1 month ago 2 Members · 3 Replies
  • Chris Borjis
    July 14, 2008 at 9:17 pm
    found the problem.
    I had to manually delete the 5.1 .pkg file from the \library\reciepts folder.
    ridiculous.
    the uninstaller should handle this like every other software/hardware driver.
  • Gary Adcock
    July 15, 2008 at 12:13 pm
    [chris borjis] “found the problem.
    I had to manually delete the 5.1 .pkg file from the libraryreciepts folder. ridiculous.
    the uninstaller should handle this like every other software/hardware driver. “
    NO — it should not–
    Not when you are going backwards to a previous file version- you were regressing the drivers and the OS was specifically designed to prevent you from loading a prior software version on top of a newer one.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Chris Borjis
    July 16, 2008 at 9:10 pm
    Absolutely it should. Every thing else does.
    an uninstaller is made to do that….uninstall.
    The black magic decklink drivers not only uninstall ALL software/drivers, but it also downgrades firmware if necessary.
    The aja uninstaller should at least tell you what to do after it finishes, but it doesn’t and thats an unwarranted inconvenience.
