Activity › Forums › Adobe Premiere Pro › LFE channel isolation in a 5.1 mix
Posted by Ralph Gould on August 1, 2012 at 6:33 pmWhen I add a 5.1 set of wave files to Premiere, I automatically get some of the LFE signal to either the L/R channels or surrounds depending on how the little panning boxes are set on the mixer. I can control the level of the LFE channel by using the bass fader on the LFE input channel. Is there any way to kill the LFE channel feed to the L/R and surrounds and isolate it to the LFE channel alone?
ThanksCarrick Moore gerety replied 7 years ago 4 Members · 4 Replies -
Richard Knight
August 1, 2012 at 7:10 pmPremiere has a problem in sending one track to just the LFE. This is the work around I use. Put the mono LFE track on two tracks above each other in the timeline. Send one to centre channel and the LFE channel. Send the other to just the centre channel BUT with the invert effect added in the mixer. This will cancel the centre feed with the origional track leaving just the LFE. This will only work if the levels are identical between the two tracks.
Richard Knight
Ralph Gould
August 1, 2012 at 9:50 pmThanks Richard. It would seem that Adobe doen’t understand that the LFE should only go to other channels in stereo downmix. Maybe they will read this and fix it.
Ralph -
Zameer Tamboli
January 18, 2015 at 3:06 pmSame here
i cannot send my LFE mix to only LFE channel..
it is feeding LR also…
?????? why ????reason only know Adobe engineer..
May god Give good Sound mixer window designer to Adobe..:)
May 1, 2019 at 1:18 amHey Ralph– I had the same issue and was looking for a solution all day until I found this tutorial:
https://www.youtube.com/watch?v=v-2jD1WDcys
The short version of what this tutorial contains is:
–create a sequence with a multichannel master INSTEAD OF A 5.1 master.
–create 6 mono tracks, panned alternately L,R,
–make sure the audio you put on these tracks is in the standard order
Track 1: L Front (panned hard left)
Track 2: R Front (panned hard right)
Track 3: Center (panned hard left)
Track 4: LFE (panned hard right)
Track 5: L Surround (panned hard left)
Track 6: R Surround (panned hard right)Although I was thrown by the Left and Right panning of the Center and LFE tracks, that’s just a way of telling the 5.1 soundsystem to isolate each of the 6 tracks to its own speaker. If you use Premiere’s 5.1 Master, it will automatically spread those low frequencies among the other speakers and there’s no easy way to isolate them.
I’m using Premiere CC 2018, so perhaps Adobe has fixed the problem or is working on it in the 2019 versions.
Hope that helps!
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
