Activity Forums Adobe After Effects Level shifts in AE CS3 renders
  • Level shifts in AE CS3 renders
    Posted by John Austin on January 18, 2008 at 5:30 pm
    When I bring a clip into AE from Final Cut and render it using the lossless setting or dv setting, the levels are crushed. I did not have this problem with AE7. I can’t figure it out.
    John
    John Austin replied 18 years, 7 months ago 20,008 Members · 1 Reply
  • John Austin
    January 20, 2008 at 3:52 am
    Under Project settings/color settings the depth is set to 8 bits per channel and working space is set to none. How should I set it?
    John
