Activity Forums Blackmagic Design Level difference in output format
  • Level difference in output format
    Posted by Robert Douglas on October 28, 2007 at 4:12 am
    Hello COW Pro’s’
    I have a Decklink HD Pro 4:4:4 in/out card that I use in tandem with a Decklink Multibridge. When I put color bars on the output of Final Cut Pro and switch my Sony BVM-1916 analog broadcast monitor between composite NTSC, and componet Y, cb, cr the visual apparent video levels (in blue only mode) between the two channels is very different. All channel outputs of the monitor are properly terminated with 75 ohm terminaters.
    Has anyone ever seen a significant difference in the level output of different channels and/or formats of analog video from the HD Pro card or Multibridge?
    I have been running the HD Pro card and Multibridge in tandem for a couple of years for editing and color grading with no problems or level differences. If I had a separate analog test signal generator I could for sure eliminate the monitor as the problem. Any input would be much appreciated.
    Thanks in advance,
    Robert Douglas
    Freelance Colorist
    Daniel5000 replied 18 years, 10 months ago 2 Members · 1 Reply
  • Daniel5000
    October 28, 2007 at 8:41 pm
    Hello
    Unfortunately, I don
