Activity › Forums › Adobe After Effects › Letters like falling leaves
Posted by Robyn Rhodes on November 5, 2010 at 9:17 pmHi There.
I need to have some letters fall into frame from above like leaves. Anyone have a suggestion?
And have a good weekend, if you have one.
r
Robyn Rhodes replied 15 years, 10 months ago 4 Members · 4 Replies -
Kevin Camp
November 5, 2010 at 10:10 pmayatoweb.com has an old tutorial that may help you:
https://www.ayatoweb.com/ae_tips_e/ae19_e.html
and a search at adobe community help for ae may have more:
but a fairly simple way would be to create your letters in a smallish comp, so a letter fills the frame fairly well and a there is a different letter on each frame.
then bring that comp into your final comp, add a solid and add particle world effect. for particle type choose textured quad poly and select your letter comp and choose ‘birth’ for texture time. move the producer off screen top and increase the longevity of the particles.
after that, it’s a matter of playing with other settings like birth rate, velocity, gravity, animation style (you might try ‘twirl’) and other physics settings.
you may also need to lengthen the letter comp to be the same duration as the main comp. an easy way to do that is to enable time re-mapping (layer>time>time re-mapping), then add an expresion to the time remapping property (animation>add expression) and type loopOut() which will then loop time for that layer. you may also need to drag the outpoint of that layer to the end of the comp.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Brian Charles
November 5, 2010 at 10:33 pmThere are several techniques that may work for you. Dan Ebberts has a great script on his site here:
https://motionscript.com/expressions-lab-ae65/confetti.html
As well if you have Particular that would yield the best results. If you do not you can use Particle World to achieve something like you describe.
Here is a file with 2 examples: 1250_fallingletters.aep.zip
Joseph W. bourke
November 6, 2010 at 8:53 pmThere’s a 3D text preset (in presets 2 – you may need to download this from the Adobe website as an additional “goodie”). It’s called “3D Falling like leaves”. Sounds like just what you want.
Joe Bourke
Creative Director / Multimedia Specialist
B&S Exhibits and Multimedia
bs-exhibits.com -
Robyn Rhodes
November 11, 2010 at 3:10 pmthanks all. very helpful
r
I’m only half the thing I say I am, the other half are me.
