Activity Forums Adobe After Effects letters forming shapes
  • letters forming shapes
    Posted by Roy Glover on April 26, 2008 at 2:51 pm
    Hi!
    I need to do an animation where there are a lot of swarming letters that gather into the shape of a flying bee. Then, the letters should spread and form another shapes. Is there a way to do this with 2d software without having to keyframe everything?
    Thanks a lot in advance!
    Darby Edelen replied 18 years, 4 months ago 3 Members · 2 Replies
  • Joey Foreman
    April 26, 2008 at 3:43 pm
    Sounds like you’ll have to do morphing using Reshape. Very tedious and lots of keyframing.
  • Darby Edelen
    April 26, 2008 at 7:09 pm
    Do the letters need to spell something out at any particular time or can they be entirely random? If the latter is the case then you should be able to use Trapcode’s Particular, or another particle system effect, to control the letters fairly well.
    If the former is the case then you might try using Card Dance to achieve the look. This should give you some ideas if you can follow along with Ayato =)
    https://www.ayatoweb.com/ae_tips_e/ae49_e.html
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
