Activity › Forums › Adobe After Effects › letters falling into a newspaper like ayato 49 example
  • letters falling into a newspaper like ayato 49 example
    Posted by Aroonzfx on April 23, 2005 at 5:47 pm
    hi all
    i have a newspaper made in photoshop
    i would like to create an animation in which the letters in the
    newspaper should fall in to a plain layer (a sheet ) to form the newspaper…
    its similar to the ayato 49 example…
    can anyone help me out with this………………….
    thanz in advance
    aroonz
    Mike Clasby replied 21 years, 5 months ago 3 Members · 2 Replies
  • Bobby Walker ii
    April 23, 2005 at 7:37 pm
    The Ayato example used card dance to achieve his/her look. You’ll need to RTFM for the exact particulars, but basically Card Dance is using a Greyscale layer to offset the z depth of the letters. For best effect you’ll probably need to use a monotype font and set the grid in card dance to match your letter spacing. Next you’ll create your grey scale map too offset the letters. That will be you biggest challenge, to create the greyscale map in such a way that some of your letters aren’t split in two.
    hth
    bobby walker ii
    broadcast video COW
    G5 2.5GHZ DP,2.5 RAM, AJA IO LA, Medea G-Raid,FCP HD
  • Mike Clasby
    April 23, 2005 at 8:19 pm
    You might also think about using Shatter, like in this tutorial:
    https://creativecow.net/articles/simpson_mark/text_shatter1/
    You should be able to use your PS files, or modify them to be like the AI files he uses. You need to make a Shatter Map (White letters on black).
    An alternative, fast and easy, is to make your newspaper all with AE’s text tool (you can use wingdings for shapes also), and to use one of the animation presets,
    like “Raining In Characters” or “Drop In Characters” (see the help files, “Creating and Animating Text 6.5>Gallery of Text Animation Presets”.
