Activity › Forums › Adobe After Effects › Letters and numbers, down the drain…
Posted by Telarium on April 9, 2006 at 11:57 pmI
Brian Charles replied 20 years, 4 months ago 5 Members · 5 Replies -
Ebarfield
April 10, 2006 at 12:16 pmThere is a “spiral” effect for text that spirals characters as if going down a drain. you can adjust the path.
“deja vu all over again” — Yogi Berra
Telarium
April 10, 2006 at 1:29 pmYeah, I did consider that, but wouldn’t that mean I have to create a path for each individual letter to get the effect I’m wanting? Seems like that would take an insane amount of time.
Ryan Hill
April 10, 2006 at 2:31 pmFoam has some nice ways to control the way it flows. I don’t remember if you can apply different frames to the particles with Foam.
Brian Charles
April 10, 2006 at 4:21 pmThere are several methods which might work with some experimentation. Particle Playground in the Pro version allows you to control a stream of characters.
Third party effects like Trapcode’s Particular can use any source as a particle.
The Foam effect can use a layer as a particle but you need to control the region the particle occupy using a Flow Map and the particle orientation needs to be controlled by its velocity. In addition each instance of the particle is identical so you may need several layers with the effect applied to achieve the desired result. Foam is applied to Solid layers and uses other Comp layers as a source for the Rendered particle. Set the wobble ammount to 0 otherwise the letters will change shape (may that would be cool.)
