Activity › Forums › DVD Authoring › Letterboxing Problem on an HDTV
  • Letterboxing Problem on an HDTV
    Posted by Alexander Zalben on May 27, 2009 at 9:11 pm
    First time poster!
    So I’ve shot a project in 720p, edited in Final Cut 5, and am looking to export, then burn a standard DVD in DVD Studio Pro 3. I’ve tried it a couple of different ways, and I keep having the same problem:
    – When I play the DVD on my HDTV, I still get letterbox bars, which is clearly squishing the image that would otherwise be the correct aspect ratio.
    Just to be more specific, the first way I tried (and I haven’t seen much change any other way), is to:
    – export from the Final Cut timeline, using Compressor, with the “DVD – Best Quality – 90 Minutes – 16:9” setting.
    – Drag into DVD Studio Pro.
    – Author, using the 16:9 Letterbox setting.
    I’ve also tried just using a full res Quicktime file (that I know is 1280×720) I drag directly into DVD Studio Pro. Same with iDVD (I know, but I had to try it).
    Every time, it’s squished to fit in the black bars.
    Any help? Even a suggestion of a workflow from an HD Final Cut timeline, to burning to an SD DVD would be extremely helpful.
    -alex
    Roman Melekh replied 17 years, 4 months ago 2 Members · 3 Replies
  • Roman Melekh
    May 28, 2009 at 6:29 pm
    Just set up your DVD player!
    Now you have DVD’s settings as “Letterbox/Pan&Scan”, and you must set to “Wide-screen”
  • Alexander Zalben
    May 30, 2009 at 4:40 pm
    Wow! I’m an idiot! Thank you 🙂
  • Roman Melekh
    May 30, 2009 at 6:20 pm
