Activity Forums Apple Final Cut Pro Legacy letterboxing in quicktime export does not work
  • letterboxing in quicktime export does not work
    Posted by Anne-marie Steenbergen on February 4, 2009 at 4:01 pm
    I have made a movie in 16:9 and I want it letterboxed (bars at the top and bottom)
    sequence settings: Frame Size 720×576 ccir 601 / dv pal (5:4)
    Pixel Aspect Ratio: PAL – CCIR 601 (720×567) Anamorphic 16:9 box checked
    I want to make a quicktime conversion export
    I have the following settings:
    Quick time
    H.264
    Frame rate: current
    Key Frames: every 25 frames
    Datarate automatic
    quality: high
    Encoding: Best quality
    Filter: none
    Size: Custom 640×360 (i’ve also tried 640×480 and the two pal settings)
    preserve aspect ratio using letterbox checked
    Deinterlace sorse video unchecked
    When I export the video I get bars at the sides instead of bars at the top and bottom.
    How do i get bars at the top and bottom?
    Thans in advance.
    Anne-Marie
    The Netherlands, Europe
    Anne-marie Steenbergen replied 17 years, 6 months ago 2 Members · 2 Replies
  • Chris Borjis
    February 4, 2009 at 5:11 pm
    what your doing is the right steps. not sure why that wouldn’t work.
    in fcp make a new sequence and nest the anamorphic sequence into it.
    it will letterbox it.
    export that instead.
  • Anne-marie Steenbergen
    February 12, 2009 at 2:05 pm
    This does not work.
    But there is a solution i heard today.
    Make your original sequence settings anamorphic
    Make a new sequence with in the settings anamorphic unchecked
    Drag the original sequence in the new sequence, FCP asks you if you want to change the sequence settings, hit the no button and voila!
    Now you have a letterboxed film which you can export
