Activity Forums Apple Final Cut Pro Legacy letterboxing – aaargh
  • letterboxing – aaargh
    Posted by Adrian Kelaty on February 2, 2008 at 10:36 pm
    pulling my hair out!!
    working on my first HD project. shot footage on Z1 in HD format and downloaded it as HD downgraded to SD. edited project and when i save it into IDVD i’ve got a letterboxed picture. fiddled with all the settings and going absolutely crackers – any ideas anyone????
    thanks
    adrian
    Ben Holmes replied 18 years, 7 months ago 4 Members · 8 Replies
  • 8 Replies
  • Walter Biscardi
    February 2, 2008 at 11:01 pm
    [adrian kelaty] “edited project and when i save it into IDVD i’ve got a letterboxed picture. fiddled with all the settings and going absolutely crackers – any ideas anyone????”
    That’s what I would expect from an HD source unless you’ve center-punch the SD timeline.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Adrian Kelaty
    February 2, 2008 at 11:05 pm
    sorry, i don’t understand what you mean :O(
  • Walter Biscardi
    February 2, 2008 at 11:08 pm
    [adrian kelaty] “sorry, i don’t understand what you mean :O(“
    HD is wide screen. Dropped down to SD, FCP would set you up at letterboxed. I would expect your DVD to also be letterboxed, so what you’re describing of your DVD sounds normal.
    The only way to avoid this is to center punch the HD image for your 4:3 SD timeline.
    Read my Blog!
  • Adrian Kelaty
    February 2, 2008 at 11:19 pm
    The real problem is, when i save it as a self-contained movie, it ends up letterboxed in a 4:3 frame, and when I drop that into iDVD, it ends up pillarboxed.
  • Zane Barker
    February 3, 2008 at 1:21 am
    [adrian kelaty] “The real problem is, when i save it as a self-contained movie, it ends up letterboxed in a 4:3 fram”
    Then ether your time line settings or your export settings are off.
    Don’t let technology get in the way of your creativity!
  • Ben Holmes
    February 3, 2008 at 8:36 pm
    Adrian
    I don’t know iDVD, but quicktime player needs to be told to play back your video at the correct anamorphic frame size, as it doesn’t take the anamorphic flag from fcp.
    If in PAL, in QuickTime player select movie information from the view menu, then select the video track in the list, then change the playback size to 1024×576 (from memory).
    Dont have a laptop with me, so my naming may be a little off. This will allow you to view your anamorphic video correctly in quicktime player – don’t know about iDVD, but DVD studio pro asks you whether each track is 16:9 or 4:3.
    Hope this helps a little
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live broadcast.
    OB Server 1 HD – Mobile FCP editing done right.
    https://www.editecuk.com/OBServer2.html
  • Adrian Kelaty
    February 3, 2008 at 9:53 pm
    Ben
    This not only helped a little – this helped a LOT
    My problem is now solved! It was all in the QT settings.
    Many thanks
    Adrian
  • Ben Holmes
    February 4, 2008 at 2:22 am
    Adrian
    You’re welcome. Glad to actually help out once in a while – makes it worth the time I spend on here when I should be working…
    Ben
