Activity › Forums › DaVinci Resolve › Letterbox – Scope on viewer
Posted by Toke Trangbæk on November 1, 2010 at 11:43 pmHi
We have a project shot on RED – 4K.
The output will be 1:2.35 – Scope… It is NOT anamorphic.Is there a way to have DaVinci put bars on the videosignal so we can see the scope? – We need to reframe a lot of shots etc.
/toke
Toke Trangbæk replied 15 years, 10 months ago 4 Members · 8 Replies -
Ola Haldor voll
November 2, 2010 at 1:28 amMight not be correct, but the first thing that strikes me is the way you setup the timeline.
Set the monitoring output to your preferred setting (SD/720/1080/2K1080).
Set a given frame size for the timeline, and use this simple formula: width/2.35 = height
Then the rest of the magic is up to how you setup the scaling of your image in the Settings.I’ll give it a spin when I (should) be up for work again in the morning, in too few hours…
Ola Haldor voll
November 2, 2010 at 9:29 amI just tested this on a project with 2K DPX now. I set the timeline to 2048×872, and Input Scaling was set to Scale full frame with crop while the monitoring was HD 1080.
The image I got on my video monitor was then cropped – same goes for the viewer in the Color page.
Good luck with your project. 🙂
Vladimir Kucherov
November 2, 2010 at 11:56 amOla, I know you can also add black to an image using blanking and a little bit of math, in the output of the format tab. That appears on the color page and the output monitor as well. However, when I render out the blanking doesn’t seem to be baked into the output. I’m wondering if there’s a way to get that to render out, because there have been cases where 1.77 w/ matted file is preferable for the client to 2.40 cropped.
Ola Haldor voll
November 2, 2010 at 1:50 pmI just tried what you said now.
In Format Page, I set the Blanking up and down to fit the cinemascope markers on my Panasonic video monitor, this had the same effect as what I did with the timeline resolution.
If you render with the resolution set to with/2,35=height – this is the exact resolution you’ll render to.
If you render with a normal resolution (say 2K or 1080p) and use the blanking, you get the same visual result, but the render is letterboxed. Output resolution must remain the same as the timeline. Only adjust the blanking.
Rohit Gupta
November 2, 2010 at 2:27 pmIn the next dot update, you will be able to render out the blanking.
Regards,
Rohit -
Ola Haldor voll
November 2, 2010 at 3:04 pmOoops, maybe I spoiled some beta info? 🙂 It does work with 7.0.3, though. Can’t say I know how that was in the previous version as I’ve never really been into that area of Resolve before.
Vladimir Kucherov
November 2, 2010 at 4:30 pmClearly you are speaking from the future.
This 7.0.3 seems to be chock full of cool things I’m excited to see.
