Activity Forums Apple Final Cut Pro Legacy Letterbox clips into 16:9?
  • Letterbox clips into 16:9?
    Posted by Thunk2007 on February 6, 2007 at 5:35 pm
    Greetings, I have a project where i have taken clips from an HVR-z1 and downconverted to letterbox DV. Is it possible to take the finished movie (which is DV letterbox) and use Streamclip and convert it into DV 16:9? Or would the best solution is to recapture the media using the “squeeze” downconvert, which will be native 16:9? I ask because I found out the project needs to be 16: 9 and it is almost finished in letterbox.
    thanks for the info
    Ben Holmes replied 19 years, 6 months ago 3 Members · 2 Replies
  • Joe Paolo
    February 6, 2007 at 8:51 pm
    For best quality reidig to 16×9. Resizing your letterboxed video would look pretty gruesome.
    joe
    joe
  • Ben Holmes
    February 6, 2007 at 11:36 pm
    Recapture. The quality drop from reformatting your letterboxed sequence will be horrendous. Use the media manager to copy the project, making the media off-line and recapture. Make sure you back up your exsisting project and project files – Media manager can be a lttle tricky.
    Ben
