Activity › Forums › Adobe Premiere Pro › Let AE use proxy with imported comp
  • Let AE use proxy with imported comp
    Posted by Andy Engelkemier on December 6, 2022 at 3:24 pm
    Not sure which forum to put this in, but the end result is Premiere, so figured I’d put it here.
    I needed to do some rotoscoping on some text. So I sent some video over to an AfterEffects file, matched the camera, added some 3D text, did some rotoscoping. Everything looked good…in After Effects. The proxy is working just fine there. I am at home, so don’t have the footage, but I have all the proxies.
    So then import that comp into Premiere, and it switches the comp to offline automatically.
    AE let me use the proxy to do everything. If I turn off everything that references the footage, then premier lets me load the footage just fine.
    Is there any way to allow premiere to use proxies from AE as well? I Would say I am surprised they didn’t pass that setting through, but….this is Adobe. They have some amazing tech, make a few good choices, and then they overlook something a toddler could have pointed out.
    Andy Engelkemier replied 3 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
