Activity Forums Adobe Premiere Pro Lesson learned with DVCProHD, 60P, and Windows Media
  • Lesson learned with DVCProHD, 60P, and Windows Media
    Posted by Vince Becquiot on October 27, 2007 at 3:27 am
    I have been wrestling with these issues for a couple of days, so I figured I would post these solutions.
    If you are bringing 60P DVCPro footage (HVX 200, HPX500, etc.) into PP CS3, and are planning to slow it down, simply interpret it as your “project” framerate (In my case 24P), and it will play in slow motion, then use time remapping to adjust the speed upward if needed. My problem? I did the exact opposite. Premiere did interpret my footage as 60P, but still removed the extra frames so that it would play as 24P. So when I used time remapping to slow it down, I go the usual interpolation slow mo.
    For Windows Media export, and possibly other exports, make sure you also remove frame blending on every clip you plan on slowing down. If you are wondering why, these samples demonstrate the difference…
    (Sorry, large files)
    With frame blending:
    Without frame blending.
    Hope that can help someone…
    Cheers,
    Vince
    Jerry Black replied 18 years, 11 months ago 2 Members · 3 Replies
  • Vince Becquiot
    October 27, 2007 at 3:30 am
    oops, the second link should be This one.
    Vince
  • Jerry Black
    October 27, 2007 at 2:37 pm
    Vince,
    the link example without frame blending is not working. Great examples but would like to see the second clip to understand the comaparison.
  • Jerry Black
    October 27, 2007 at 2:39 pm
    Naturally, I found the second clip–big difference. Great way to illustrate the effect!
