Activity › Forums › Apple Final Cut Pro Legacy › Leopard upgrade okay?
  • Leopard upgrade okay?
    Posted by Bob Cole on December 30, 2008 at 4:32 am
    Has anybody had any problems with existing FCP 6 projects, after an upgrade of the OS from Tiger to Leopard?
    I am considering an upgrade to Leopard in order to run FXFactory Pro 2, but am in the middle of several editing FCP projects and don’t want to jeopardize them.
    Thanks.
    Bob C
    Jerry Hofmann replied 17 years, 9 months ago 3 Members · 2 Replies
  • Rafael Amador
    December 30, 2008 at 4:42 am
    Hi Bob,
    Shouldn’t be any problem for the FC projects. However if you are in the middle of few projects you should consider wait to finish the projects before up-dating. And, off course, as my good friend David Roth always advise,clon your system before the up-grading.
    What I don’t recommend you is to install the last Leoppard up-date (10.5.6) it seems is giving few problems.
    FC 6.0.5 with QT 7.5.5 in MacOSX 10.5.5 is fine.
    Cheers,
    Rafael
    http://www.nagavideo.com
  • Jerry Hofmann
    December 30, 2008 at 5:01 am
    Do the upgrade totally clean though…. i.e., erase and install leopard, then install your apps after updating it… don’t just push the upgrade button on a new OS install… ever.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
