Activity Forums Apple Final Cut Pro Legacy Leopard Finder Not Finding?!?
  • Leopard Finder Not Finding?!?
    Posted by Max Frank on June 8, 2008 at 8:42 am
    I’m on 10.5.2.
    When I do a search through Finder, it doesn’t find files that I KNOW are there.
    I’ve got about 4 FW800 drives daisy-chained, and one other Mac with 2-3 drives connected via the network.
    But Finder is having a hard time finding files on several of the drives.
    Is there a way to index the Finder to force it to search all drives, or is the problem the more probably ‘user’ [ie, me doing some shtoopid].
    To clarify, my Finder can SEE all the drives, and I navigate, copy, etc via the finder, it just doesn’t seem to SEARCH all the drives, all the time.
    Any ideas?
    Wayne
    Chuck Reti replied 18 years, 3 months ago 4 Members · 3 Replies
  • Rafael Amador
    June 8, 2008 at 9:52 am
    Hi Wayne,
    The problem may come from FC, or may come from your System.
    When I have this kind of problems I start by making sure that the System is OK. You have thousand more possibilities of a malfunction in the System than in FC. If after optimizing the System-HDs, the problem remais, then I start to clean FC.
    So, repair permissions, cleaning caches and DiskWarrior or TechTools. If no improvement, trash permissions, etc
    Cheers,
    rafael
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Gunleik Groven
    June 8, 2008 at 4:42 pm
    I’ve seen this a lot when I batch export a large number of files.
    It seems spotlight needs “some” time to update its database before it can find stuff.
    This can vary from a couple of seconds to about an hour…
    Gunleik
    https://www.vulture.no/
  • Chuck Reti
    June 8, 2008 at 5:33 pm
    Make sure your Spotlight Prefs (System Prefs>Spotlight>Privacy) allow indexing of those volumes, which, as mentioned, does take some time to do. You could also use, as I do, a third-party search app such as DevonTechnologies’ EasyFind . Fast, and easily customized to search wherever and for whatever files you wish.
