Activity Forums Adobe After Effects lensflare on white background
  • lensflare on white background
    Posted by Bender on May 31, 2005 at 8:10 pm
    hi
    how can i add a lens flare to a white layer (compostion background is also white). with any other color it works fine but not with a white colored layer!
    thanks very much!
    an intern from europe in nyc
    Bill Clotz replied 21 years, 3 months ago 4 Members · 3 Replies
  • Barend Onneweer
    May 31, 2005 at 8:47 pm
    Due to the nature of the lensflare phenomenon (light bouncing around inside the lens construction) there isn’t such a thing as a lensflare that’s visible on a completely white background.
    Two options: make your background a light grey, so the lensflare stands out.
    Or for creative reasons you could do a lensflare on a black background and invert the result. Won’t look realistic, but you get an inverted lensflare on a white background.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Matt Stoltz
    June 1, 2005 at 1:16 am
    try this-Ive done this many of times–on the lines of what Barend said
    Take your main comp and (the one you created everything in –PreComp all those layers into a new comp
    then add a solid black layer-add a lens flare on the black solid -then on that layer -set it to screen blending option in your transfer or blending modes –
    hasnt failed me
    matt
  • Bill Clotz
    June 1, 2005 at 2:59 am
    Create a black solid above your white layer and then apply the lens flare to this black solid. Then apply the “Shift Channels” effect and set it to take alpha from luminance (or also try taking it from red). Then apply the “Remove Color Matting” effect.
