Activity Forums Apple Final Cut Pro Legacy Lens Smuges Requires Serious Magic
  • Lens Smuges Requires Serious Magic
    Posted by Rob Gee on October 16, 2005 at 7:54 pm
    A tiny smudge on the lens was not seen until later. Is there a way, though FCP or a compatible plug-in, to go in and digitally correct this? I’m still fairly new to FCP and the bag of tricks I have knowledge of is small indeed. I’m thinking there must be something that goes in and replaces the smudge pixels with copies of pixels that neghbor the smudge pixels.
    Any help would be appreciated. – Rob
    Alexander Kallas replied 20 years, 11 months ago 5 Members · 4 Replies
  • K Hendrickson
    October 16, 2005 at 9:03 pm
    I just got the same assignment, one of our shooters had a spot on his lens that he needs removed or at least minimized. My plan is to bring the footage into AfterEffects, mask out the problem spot and fill the mask with the same piece of video shifted slightly to one side. His stuff is mostly nature stuff, running water and rolling clouds, so I may be able to get away with this. As I say, though, it’s the plan . . .
    Kris
  • Max Frank
    October 16, 2005 at 9:24 pm
  • John Burgan
    October 16, 2005 at 11:15 pm
    Check out Klaus Eiperle’s CGM Clone Area filter
    https://www.cgm-online.com/eiperle/workshops/workshop23/workshop_e.html
  • Alexander Kallas
    October 17, 2005 at 12:17 am
    Yes,
    The CHV clone plug-in is really cool.
    Easy to use on static camera shots. For pans you go frame by frame,
    Cheers
    Alexander
