Activity › Forums › Sony Cameras › Lens Protection for EX3
Posted by Renny Mccauley on August 11, 2009 at 8:04 pmI want to purchase a clear glass protection filter for the EX3. I’m worried about it fitting behind the stock matte box. Does anybody know any specific filters that are thin enough to fit?
RennyRenny Mccauley replied 17 years, 1 month ago 4 Members · 6 Replies -
Noah Kadner
August 12, 2009 at 11:18 amYou mean a screw-in? I’d be surprised if most standard ones didn’t fit fine.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, and Panasonic DVX100.
https://www.callboxlive.com -
Clint Fleckenstein
August 12, 2009 at 2:20 pmI have a standard UV filter screwed into ours. It must be removed to use the stock Sony wide angle adapter, as I found out in the dark last night while trying to capture the meteor shower. By the way, the results…not good. I got great stuff with my DSLR, but the EX3 was mostly noise. I was using slow shutter mode and 1-sec interval recording, iris slammed wide open and 6db gain.
Cf
Renny Mccauley
August 12, 2009 at 3:06 pmI just had read some stuff that on the EX1 people tried to put filters on and couldn’t get the mattebox back on. Maybe it’s not an issue with the EX3.
RennyRenny McCauley
SkipJack Studios, MD -
Bruno Perosa
August 12, 2009 at 4:37 pmB+W-77mm-MRC-Slim-UV-Filter is the one you want.
EX3, MBP17″2.93GHz, FCS2, Media100, BtcSP, DVcam
Clint Fleckenstein
August 12, 2009 at 8:20 pmI had a UV and CP filter on today and couldn’t get the stock attachment on. I didn’t try it with just the CP filter on it, but it looks like it would be a tight fit.
I also found out today that I can sprint through chest-high weeds pretty quickly with an EX3 and extended Miller tripod when an irrigation rig turns on me! I’m happy to report that I have dry gear and a wet van.
Cf
Renny Mccauley
August 13, 2009 at 12:13 amThanks for the tip Bruno.
RennyRenny McCauley
