Activity Forums Maxon Cinema 4D Lens flare size not controlled by distance
  • Lens flare size not controlled by distance
    Posted by Graham Quince on November 10, 2008 at 9:16 am
    Hi
    I’m trying to fly past a light onto which I’ve attached a lens effect, but the size of the flare does not seem dependent on the distance from it. Obviously, I could replace the flare with a visible light setting, but that isn’t as ‘artistic’ as a post-effect flare.
    I could keyframe the brightness of the flare manually, but is there a better way?
    Many thanks in advance
    Graham
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
    Brian Jones replied 17 years, 10 months ago 3 Members · 2 Replies
  • Randy Johnson
    November 10, 2008 at 9:41 am
    Xpresso has a couple ways to do this. I dont have time to post any files but if you drag the light with the effects into the xpresso editor you can set the FX glow brightness to something like the camera a better way is using FX fade to approaching object but that involves a little more effort.
    /Randy
  • Brian Jones
    November 10, 2008 at 3:29 pm
    check off Glow Distance Scale in the Light Object’s Lens tab (and possibly Reflex Distance Scale if you are using Reflex)
