Activity Forums Adobe After Effects lens flare on white background
  • lens flare on white background
    Posted by Chris Read on April 11, 2011 at 8:01 pm
    I am dong a logo project for someone who wants the background to remain white and the text black. There is an instance in which i need a light ray to appear and flash across the writing, i wanted to use lens flare but it won’t appear on the white background. Is there a way i can get round this or a similar effect i can use?
    Phil Radelat replied 15 years, 5 months ago 2 Members · 2 Replies
  • Phil Radelat
    April 12, 2011 at 2:25 am
    Dave is correct, however you can make a faux flare by multiplying itself on the white areas. Use the text as an alpha so you don’t multiply it over the text or it will disappear from the text area.
    You may need to make more than one multiply layer, and possibly use and additional keyframe-able soft vector alpha to keep the heavier components of the flare in check.
  • Phil Radelat
    April 13, 2011 at 1:10 am
    I forgot this isn’t Photoshop. 🙂 You’ll have to render your flare against black first and extract an alpha from it before you can try my approach.
