lens flare on path
Posted by Rdub on April 27, 2005 at 2:33 amCan I have a lens flare follow along a circular path?
Kurt Murphy replied 21 years, 5 months ago 3 Members · 2 Replies -
Jon Okerstrom
April 27, 2005 at 3:05 amHi Bill,
Yes you can, in a variety of ways.
One way is to manually keyframe the position of the flare over time. I’ve done this to have a small lens flare follow a highlight glint as a 3D object moves before the camera.
Are you using Knoll Light Factory or something else?
Jon
Kurt Murphy
April 28, 2005 at 6:49 pmAnother way is to add a couple keyframes in the beginning and end of the flare path. Next, double-click the Layer to bring up the Masks, Anchor Point and (little known) Effects path. From here Select the Flare and you’ll see a path bezier. You can now curve the path using the tangents.
Hope this helps,
kurt
