Activity › Forums › Adobe After Effects › Lens Flare on Alpha Channel
Posted by Paul Whishaw on March 18, 2009 at 1:41 amI haven’t spent a lot of time working with the lens flare effect because I can never get the bloody thing to work on an alpha channel. Surely this is possible. I have used it in a few projects with the Screen mode applied but to try and get it to work on an alpha channel no. I am trying to get it to work with a screen wipe.
Is there a way to do this and leave the alpha channel so I can use it as a wipe?
Junior Lopez replied 13 years, 5 months ago 8 Members · 9 Replies -
Simon Bonner
March 18, 2009 at 3:49 amSo you just want the lens flare with no background, so you can drop it over a cut?
Apply the lens flare to a black solid and set the transfer mode to screen. Render. Then import the footage and add to your final comp and set it’s transfer mode to screen. This will get rid of the black pixels, making it look like you have rendered with a alpha channel.
Someone might have an idea of how you can render a lens flare without the bg colour, but this method works fine.
Simon Bonner
youtube.com/simonsaysfx
Chris Wright
March 18, 2009 at 4:34 amYou can use the free Unmult from
https://www.redgiantsoftware.com/downloads/archive-versions/#knoll-light-factory-unmult
then you can do cool things like make the flare create a special cross dissolve with it set to stencil alpha.
David Bogie
March 18, 2009 at 2:33 pmUNMULT totally rocks. Why it’s never been incorporated into AE is beyond me.
I’ve never tried this but I’m sure there must be a simple way to use Set Channel or Set Matte to pull the luma information form one layer and use it to create an alpha.bogiesan
Chris Wright
March 18, 2009 at 10:00 pmHere’s a free flare wipe.aep you can monkey around with. It uses a flare to create a silhouette alpha that transition wipes 2 pictures back and forth. It’s subtle and beautiful. Works in cs3. Just replace the two pics/footage with your own.
https://www.megaupload.com/?d=6JINJEBA
Darby Edelen
March 19, 2009 at 12:14 amYou can do this in AE by creating your lens flare on a black solid, pre-composing the lens flare, then applying the ‘Set Matte’ effect to the pre-comp and changing its blend mode to Luminescent Premultiply.
If you don’t change the blend mode to Luminescent Premultiply then your black background will be incorrectly multiplied into your image.
The downside of this technique is that you need to go into the pre-comp to animate the lens flare.
Darby Edelen
Chris Wright
March 19, 2009 at 12:45 amCan this wipe 2 pictures like a vertical wipe transition? I’m trying to figure out your final output. lol.
Kirk Tabalotny
May 19, 2009 at 12:31 pm“You can do this in AE by creating your lens flare on a black solid, pre-composing the lens flare, then applying the ‘Set Matte’ effect to the pre-comp and changing its blend mode to Luminescent Premultiply.
If you don’t change the blend mode to Luminescent Premultiply then your black background will be incorrectly multiplied into your image.”
Darby – is this going to be the only option available as an alternative to Knoll Unmult, for Vista/XP 64bit users? (apart from dual-boot 32 bit+64 bit OS set-ups). Pity Unmult got archived before 64 bit systems became viable.
Kirk -
Jim Goertzen
January 26, 2011 at 6:35 pmDarby,
Almost two years after posting, your advice saved my butt! I work for a large national broadcaster who has set ‘administrative log-in’ privileges on my computer OS, preventing me from being able to install the UNmult (or any) plug-in. To have someone ‘authorize’ this simple plug-in installation would have likely have caused days of delay. Your solution saved the day!
Thanks!!
Jim
