Lens Flare jerkiness??
Any one know why AE is doing this to me??
The lens flare source point is to stay on the tip of the star and the lens flare jumps around, i tried to make it not move on the X axis but it did not help. it still jerks from left to right.
here is the image, if you go frame by frame you will see The circle on the lower left behind the text jumps around.
https://gallery.me.com/mj662#100062/Lens%20Flare%20jerky-H.264Any insight would be appreciated.
Thanks, Mark
