Activity Forums Adobe After Effects Lens Flare Issue
  • Lens Flare Issue
    Posted by Amber Navarrete on September 17, 2008 at 7:01 pm
    Hello,
    I went through this tutorial: https://www.graymachine.com/tutorials/lensflare.html
    It shows how to create a really awesome looking lens flare. Though it has you apply all effects to a solid layer. In the end I can’t seem to put it on top of other video effectively. I want to be able to put this on top of any image and still have control over it. Can anyone help?
    Much appreciated as always!!
    -Amber
    Amber Navarrete replied 18 years ago 2 Members · 4 Replies
  • Darby Edelen
    September 17, 2008 at 7:24 pm
    Try placing the composition above your footage and changing the blend mode to ‘Screen’ or ‘Add.’
    Darby Edelen
    NVIDIA
    Santa Clara, CA
  • Amber Navarrete
    September 17, 2008 at 7:28 pm
    I tried that. It doesn’t look right – it changes the color of the comp that I’m trying to apply to. Is there a way to make the solid transparent? Of course I can bring down the opacity but that means I loose the effect as well. I want the effect to be on a transparent layer. Tried null – that doesn’t work either.
  • Darby Edelen
    September 17, 2008 at 7:38 pm
    Alright, try this then:
    1) Apply the Channel > Set Matte effect to the flare composition and change the “Use For Matte” property to “Luminance”
    2) Change the flare composition’s blend mode to “Luminescent Premultiply.”
    Darby Edelen
    NVIDIA
    Santa Clara, CA
  • Amber Navarrete
    September 17, 2008 at 7:47 pm
    You’re amazing. That worked perfectly. Thank you thank you.
