Lens Flare causing Black BG
I’m following an Andrew Kramer tutorial, and I encountered a problem.
The lens flare on the ring cuases a black bg when I layer this comp on top of an other. Basically, then lens flare layer is causing the alpha of the later to disappear.When I disable the lend flare layer I regain my alpha.
Is there some way around this problem, while still keeping the lens flare layer?The only solution I found is to set the comp to ‘add’ inside the other comp it sits in, but that doesn’t give me the best results.
In the attached pic, you can see the lens flare. and the layer structure.
Also in the other pic you can see the alpha when I have the lens flare layer disabled.Thanks!!
