Activity Forums Adobe After Effects Lens Flare and Alpha Channels
  • Lens Flare and Alpha Channels
    Posted by Brad Strickman on February 21, 2007 at 8:07 am
    I created a black solid, added a lens flare, and set the transfer mode to Add. When I view the Alpha Channel, the black is appearing somewhat opaque. I do not understand why this is happening. Any solutions?
    Barend Onneweer replied 19 years, 6 months ago 3 Members · 3 Replies
  • Mylenium
    February 21, 2007 at 10:46 am
    [bdstric] “When I view the Alpha Channel, the black is appearing somewhat opaque. I do not understand why this is happening. Any solutions?”
    What’s to understand? You didn’t change any values on the Alpha channel, so it naturally is fully opaque. Most belnd modes only work on the color channels. If you need Alpha, the nunmultiply using XMult, Knoll Unmult or Walker Alpha tool.
    Mylenium
    [Pour Myl
  • Brad Strickman
    February 22, 2007 at 5:38 am
    I completely understand what you are saying, but I am not sure which tools you are referencing. Could you please explain further. Thanks
  • Barend Onneweer
    February 23, 2007 at 11:12 pm
    You could have tried googling “Knoll Unmult”… But basically it created an alpha channel for elements on a black background. Originally aimed at compositing explosion footage, but works well on lensflares.
    And it’s free.
    https://www.redgiantsoftware.com/unmult.html
    Bar3nd
    Raamw3rk – digital storytelling and visual effects
